I'm wondering if this is a common issue?
I am able to load a module for "Convert Forms" (excellent product by the way)
but for some reason when I make a custom HTML Module and insert the shortcode, it only loads the syntax and not the module. I wonder if I'm missing a setting or if this is standard behaviour? I remember that tinymc was stripping out html, but i've even tested it turned off and we managed to fix that issue a while back. Is there perhaps another feature or parameter that needs to be turned on/off?
{convertforms 2}
Please see attached screenshots for examples:
This issue happens when the Prepare Content option is not enabled in that custom HTML module settings.
I see the form on your site now, it seems that you've already figured it out.
4 months later
