I tried to publish the check availability Module.
I follow what is said on the documentation page but it gives this message on frontend :
"No default and published property found. Make sure that you have at least 01 default property in your system and it must be published."
Strange....there is a property and a room published on Solidres backed !
At this time nothing is working fine with this template... Is it sure it's really designed to work with Solidres ????
