HI George,
As I can see that both default page of EN and GR were using the same template style: JA Alpha - Home and of course, it will show the menu set in Navigation settings only.
You should clone this template to have a new template for homepage of Greek, then in Navigation settings, clone the default navigation profile to have a new one and assign main menu of GR for it.
I just updated for you, kindly check.
