Hello, can You help me disable Main Body only on start page in Purity IV? Thank You.
    Hi kodaaygo ,
    Here is the step you can disable.
    1. You should create a template style for the start page, I think it is Home page.
    2. In the template style, you can clone one layout or using a pre-built layout from the dropdown. You can select the "landing" layout that is designed for landing page without the "component" (Main Body)
    3. If you are using a different layout and want to remove the Main Body, simply remove the "component" position.
      Regards.
    Thank You, everything works great.
    Regards.
