forty Hi
It seems that your site is still trying to load the system.css file, you can access the head block of template on your site and remove / comment the code which is calling this file as suggested here: https://www.joomlart.com/forums/d/47615-multilanguage-homepage-problem/28
and see how it goes.
P/s: I tried to log into backend of your site: /administrator but it always redirects to frontend instead of admin login screen.
Ok i did the same and it is working
