I've a little problem.
I've imported a layout and make it as the home page, but the menu is not working as it is supposed to be.
Can you hel me with that?
I've installed a fresh joomla 4 instalaltion.
I've installed T4 components and plugin
I've imported a layout (in this case the wedding one)
I've linked to imported page to the main menu and make it the home default
I've remove all the "original" modules (as main menu, login form and breadcrumbs).
Everything seems working except for the top / header menu.
It appears like that:
Insted of:
And also the template is not 100% wide.
Can you please help me with that?
Thanks you very much
