Hi Nic,
as you recommended us we renewed the license but unfortunately had a lot of troubles.
The new version doesn't work (problems with the layout and we cannot open on the lessons), so we turned back to our previous version but then other problems occured.
We still need to fix the pdf layout problem, but other than that, at the moment inside the course, when trying to edit a lesson (such as change the title and save it) or creating a new lesson, it is not possible to save the changes. (While it is possible to edit the media)
This is the error:
Notice: Trying to access array offset on value of type int in /home/customer/www/formazioneyoga.it/public_html/administrator/components/com_guru/models/gurudays.php on line 29
We are not able to fix this problem, and need a qiuck help!
Thank you very much
