We have a " Guru > My courses" link in our main menu. This takes the user to their courses, in a section with a nav bar including links to other sections "Profile, Courses, etc."
The problem is that the URL created by the menu item and the URL to "My Courses" in the Guru nav bar are totally different, and this means the style, modules associated to the menu and others are not the correct ones.
The link to "My Courses" offered in the Guru nav bar and the menu item "My Courses" in the main menu should offer the same URL. How can this be solved?
Thank you!
Best,
Roger.
