I have a problem calling my products. When I call the products link from the category page, everything works perfect, but when I call the links from the homepage, out off the different modules it does not work.
maybe you can help
regards Chris
Hi Chris,
Virtuemart requires at least one menu item for Top Level Category so links can work properly. I temporarily change the 'Offshore' item from 'Menu Heading' type to this type so it can work for now.
You can change this back and create other menu item for this type as you wish.
your the best thank you.
but one little thing: the links in Latest/Top Rate/Best Seller still not working
regards
Maybe cache on your browser? as I tried to click every product on this section but it redirected to correct detailed page
