In the module "Features Intro : style-1" when editing content in the "Feature details" elements at the bottom "Feature image" are set to required, this makes editing the content frustrating because you have to add a temporary image, edit content wording etc, save, then remove the images and then you can trick it to save without images, which the template then replaces svg generated tick image. ie.
Please fix.
Required images should not be required
Thank you, also I noticed that in the same area if the title is left empty it still renders empty h4 tags but this does not happen on your demo site.
