HI,
I installed a plugin (JUX before/after) but when I insert the code to activate it in the article, the images are not displayed, but the code.
If, however, I insert the plugin into a module, when I call the module in the article, it doesn't work but this time too it displays the code string.
I also have problems if I need to embed an iframe, this only works if I disable the joomla editor.
If I do the same tests in a clean Joomla installation, with the standard template, everything works perfectly.
Could you help me?
After a bit of research I understood what is the cause of the modules and plugins not being displayed in the articles.
I'm not a developer, but while searching I found the solution, at the following link:
https://forum.joomla.org/viewtopic.php?t=892267
The template has a customized view of the articles, I disabled it as shown in the link and now everything works.
I hope I have been useful to someone, I hope that the problem which I see is not only mine is fixed by the Joomlart developers.
    Hi mommottistudios,
    Thank you for sharing your feedback. If you encounter any issues or have questions, please don't hesitate to reach out. We're here to assist you and ensure everything gets resolved smoothly.
