Hi. I have a clean instalation of JA Seven in Joomla 5.1.0. I have set the JA Seven Default as default template style. I created Menu item of type portfolio 1 and assigned category. I created an article in that category and I chose portfolio-1 layout and saved it. However the Portfolio info Tab does not appear (same if I chose portfolio-2 layout for article).
Is there something I am missing?
Thank you
