Hello, I cannot use the "select" button to insert an image in articles, modules, or to insert the logo in the template.
The only thing that works is pasting the link to the image. (See Appendix)
If I try, it shows "Internal server error."
This is a copy of a website, which was originally created in Uber with the T3 framework. It is temporarily located on a sub domain.
It is now set up with the template JA Impact and T4 and when it is ready will replace the Uber website.
Regards Tor
    norwegian69 Hi
    You can make a test with Cassiopeia - the standard template of Joomla and see how it goes. This internal server error often relates to the server side, you can reach out to your hosting provider for further checking as well.
    yes same error with Cassiopeia.
    I will check my server, but I guess it is something with an old site in new T4, also on an subdomain, that mismatch on the server, thanks anyway.
    Regards Tor
    Let me know if you need any further assistance.
