How do I create the right module next to the main body component in JA Purity IV? I'm doing the following, and it's not saving Main body > Component > configure > add column.
You should be able to configure this in the row/section configuration of the main body on your site.
You can share the URL + super admin account so I can check for you.
I edited and added the url and password.
I just added the sidebar-r position into the right side of component block and it worked:
Pls review again.
