• General
  • Subscription issue. Please help!
Hi there,
is anyone here from Joomlart sales department? I have an issue with my paid subscription... :-(
    lphig1 Hello,
    Your latest JA Pro membership purchase should be active now. Please check again.
    We're sorry if there was a slight delay in activation.
    I'm not sure if this is correctly categorized here: I have an active Pro Plus (JA+GK) license and am trying to download the latest JA Slideshow Lite 1.2.9, but can't download the extension individually as this is rejected. Nevertheless, I can select and download the extension (but then only in version 1.2.4, for example) with a JA template such as JA Mitius or JA Zite from the individual download package. What is the best way to get the latest version?
    Many thanks in advance.
      kfloegel Hi,
      We have a separate membership for accessing JA extensions called JAEC, which you can obtain here. This membership provides access to all JA extensions and their latest updates.
      However, it should be fine for you to use the extension provided on the template page, as that was the specific version we used for testing with the template.
