Hi, I have a problem with News Show Pro Gk5 version 2.2.1 on Joomla 4.4.6, the thumbnails are deformed and in the settings the “Thumbnail Stretch” command is not available.
What can I do?
    the module no longer creates thumbnails, for old articles it did and in fact they are displayed correctly:
    https://www.poetrytherapy.it/arti-terapie
    the first thumbnail is not a thumbnail, it's the original and stretched image, the others are thumbnails.
    5 days later
    theAnt Hi
    You can try to use the Inspect Element in your browser >> disable the display: none; style of this input and enable this option >> then save the module:
      21 days later
      saguaros
      Thank you for your response and sorry for the delay.
      The real problem is that although the “Create thumbnail” option is checked, the module does not create any thumbnail but shows the original images, stretched or not. I don't understand why, until last month it was working normally. Debug reports no error.
      You can see it here: https://www.poetrytherapy.it/
      It seems a owner/permission issue. In the screenshot on the left an image uploaded via JCE that works (GK News correctly creates the thumbnail), on the right an image uploaded via Joomla Media Upload feature that GK News show as is whitout to create thumbnail
      Uploading all images via JCE it works fine.
