Dear sirs good morning .I have a problem with my site in domain https://gtst.gr.I used template of joomlart UBer : "uber home" template like this of your demo : https://uber.demo.joomlart.com/ I made all the configurating actions so as to have my site in this template . Suddenly all the modules disappeared from front page. Could you fix it please so as site will shows again like the template uber home ? With regards George
Hi George,
As I can see that you load the home position on homepage but no module is being assigned to this position.
home
Kindly check again.
Could you please fix it ? Because i have not understand my fault …..so as to correct this … Thanks so much
georgentzanetis In the Layout tab of template style assigned to homepage, the uber-home position should be loaded instead of home position.
uber-home
I updated for you and modules on homepage are showing now.
