good morning, after installing ja megastore the images are not resized, while the product data sheet is displayed incorrectly. I'll send you the link to see the problem.
to view product sheets and product photos in the cart
dierredb Hi
Could you share the URL of page where I can see the issue?
and tell me how you want it should be.
dierredb I tried to access backend of your site but it requires another login step, could you share this login info?
Hi there,
This settings in VM was not enabled so it lacked of some styles:
I enabled it and it's ok now. Kindly check.
