After GK_Storefront upgrade to latest version (Joomla 3). I have several bugs on mobile display I reported on premium tickets whitout having a fix or tip.
  • Mobile menu is not working : blank squares are displayed and not the menu links expected.
  • 404 errors on links to CMS pages (Joomla\Component\Content\Site\Helper\RouteHelper' not found)...
  • Login form is not correctly diplayed on mobile (vertical) (too wide for mobile screens)
    Do you have an idea about how to fix that ASAP ? I loose many customers because of that.
I fixed the mobile menu using the CSS (font-color was white on white background)
changing it as black and resizing the block fixed the display.
I still need help for the other issues.
regards
    5 days later
