Hello, I have a problem with the Ja impact template mega menu. I can't change the horizontal and vertical order of the submenus in the mega menu. (see screenshot) However, the order is correct in the joomla main menu. Thanks for your help.
nadegea Hello
It should inherit the order of the menu items in that menu.
You can share the super admin account of your site so I will take a look.
In the megamenu configuration in template, I just de-select these 2 menu items and select again, and it's showing in correct order now.
Kindly check.
Hi, It was that simple. I'd tried lots of things, but I hadn't thought of that. Thanks a lot
You're welcome 😉
