1. Below are the categories: JA ACM Module
https://static.joomlart.com/images/template/ja-podcast/docs/podcast-categories.png
[Container] Tabs : style-1
I followed the whole steps for this and does not work.
On quick install it works, i copied everything on my existing website but does not work.
It works on quick install but without its impossible to create, please help.
saguaros Hi i managed to do it.I have another problem everytime i load the webpage, theres some kind of script that moves the site to this area. Do you know how to remove this please?
    cloudten10 Which script are you referring to?
    If possible, pls share your site login info so I can check for you.
