Hi. I have an installation of JA SEVEN 1.2.2
I have installed the smile pack by tassos.gr and using the gallery module. When I click on an image of the gallery on desktop, it opens smoothly in a lightbox. When I do the same on smartphone (real smartphone or smartphone view through chrome inspector), nothing happens and the screen freezes, until I refresh it.
I have installed the same module from smile pack in another test environment that runs JA SEVEN version 1.1.1 and it works perfectly in any screen size.
I guess something changed after 1.1.1 and creates confilicts. Can you please suggest a solution?
Thank you
Issues with lightbox in small screens (phone, tablet etc.)
I forgot to mention that switching to Cassiopea template the smile pack module worked fine as well in any screen size.
- Edited
As the developer of the extension informed me, the problem seems to be caused by the "template/ja_seven/js/template.js" JavaScript file - specifically, the last lines (117-125). These lines did not exist in the respective file of version 1.1.1 of the template. I commented out those lines and now it works.
Perhaps this should be taken into consideration for the next updates of the template.
