Hi!
We want to change old template Mixstore to JA Vitality but we have a problem on Category view and Product view.
We use Custom Fields for all plugin and conflicts with new template. Shopper must choose variant. Old template works ok.
Old template
New Template Category
New Template Product
Hi @forty,
The override layout for the shop on these two templates is different, so you need to customize the layout on the JA Vitality template to be the same as on the JA Mixstore template.
Kind regards,
    cssyeah I don't want the same layout! I need template to work good with "Custom Fields for All" plugin.
    Old template is to see how it works with variants (Child products).
    It is supposed that this plugin is working good with VM default template so must work with JA Vitality.
    I don't think i must make customizations to work about this plugin. Your template must work good with this plugin because it is one of the most used plugins for VM. If i ask developer of thePlugin he will say.. talk to Template builders....
    So i think your template must work with this plugin or help me to do this.
    If remove overrides is not fixed.
