Form my website i uninstalled the T4 Framework and Ja Purity IV from my Joomla version 5.2.3 and now I have problems in creating category pages from the Joomla menu.
When I go to create a new BLOG CATEGORY from menu the system generate this link:
index.php?option=com_content&view=category&layout=__ja_purity_iv:new
instead of the classic: index.php?option=com_content&view=category&layout=blog
The problem is serious and is structural. Help me solve it
    7 days later
    angelino Hi
    I've forwarded to our dev team for further checking on this.
    I will keep you posted.
    Bonjour. J'ai le même problème ... J'ai installé JA Purity IV et le framework T4 car je souhaitais une mise en page plus "magazine". Après quelques tests, sans avoir jamais mis ce template 'par défaut", j'ai aussi ce lien ... Merci pour votre aide.
    angelino You can backup these 2 files and replace with attached file (unzip first)
    root/templates/ja_purity_iv/language/en-GB/en-GB.tpl_ja_purity_iv.sys.ini
    root/templates/ja_purity_iv/html/com_content/category/new.xml
    newxml.zip
    3kB
    en-gbtpl-ja-purity-ivsysini.zip
    4kB
    Super grand merci! Le problème est résolu!
