Hi all, (since last week) when a new user try to fill the registration form, it happens that the captcha (http://www.sindirettivo.it/cida/component/users/?view=registration) is not visible : the field label is present but nothing more... the plugin is active and configuration is ok with default captcha. What can I do...? Thanks in advance as usual Vivaldo
moscavi Hi
Can you also add your admin and ftp details in edit fields in order for us to take closer look.
For reference, You can follow thread post (5 point) procedure.
Hi Aman I read the documentation but didn't understand where to find the EDIT FIELDS to insert admin and ftp details. I must create a new post? Thanks Vivaldo
sindirettivo I must create a new post?
No, You can add the same in this similar post for reference where you are facing relative issue or have some query
You can edit and enter the details in edit fields following the screencast as shown
Hi Aman, I've seen your screencast but my reply button doesnt have the dropdown... Another way? Thanks V.
Are you using any browser extension like Grammerly or something similar?
This can affect the functioning of the forum
Thanks Paul
Hi Paulus, nice to hear you. All the users are experiencing this problem in sign up... Thanks as always... Vivaldo
Hi Paulus, I workedaround the issue installing a different captcha plugin and disabling the google one... Now everything works... Thanks Vivaldo
Hi Vivaldo
Thanks for posting your solution
We've marked this thread resolved
Best of luck with the site
Cheers Paul
