theroamer
In Joomla, Login Form / Registration Form / Password Reset / etc... has its own menu item type. If there is no menu item of above types, when you click to open, it will open in active menu item page (as what happens on your site).
I just created a new menu item with type of Password Reset under the menu called 'My Menu' , now when you click to reset password, it will open the form under this menu item. Kindly check.
Note: I added the menu item in 'My Menu' menu for sample only, you can move to any other menu as you wish.
