Hello, I'm looking to get some templates and see there are different versions for each item: about the templates what is the difference between the "Quickstart" zip folder and the other folders? Thanks a lot, bye.
info products
12may about the templates what is the difference between the "Quickstart" zip folder and the other folders?
I'm a little unclear what the other folders are - can you elaborate?
Regarding a quickstart this is a demo version of the site - so pre-installed are modules, extensions etc together with sample data
The template is pre-configured to match the demo
If you need any more information please ask any question
Cheers
Paul
Hello Paul, thanks for replying. For example I mind as in the screenshot: if i want to get the purity template, what are the differences between the several packages as in the screenshot? Thanks a lot, bye.
Hi Again,
The first is a 20mb file so this is the quickstart demo version of the template so includes framework, template and sample data - the bulk of the file size will be images and an install of the Joomla system itself
e.g. extract into an empty folder and then install the joomla install and select to install sample data during the install process
The second file is the standalone template and nothing else - it is the same file as used in the quickstart
The third is the plugin that has to be installed and enabled for the standalone template to work - this file is included in the quickstart
The fourth is the Joomla Art extension manager - this makes installing updates of the plugin and template easier
If you need more information on above please get to me / us
Have a great weekend
Cheers
Paul
