that would be great
Difference between ZT2 pkg 2.3.7 and mod 2.3.9
ok bear with me
I will need to update a few bits of the template, update Joomla and upload the site to dropbox
I will then need to email you with a link to download the files - is the email attached to your account ok?
The file will be a akeebe backup file so you would need to upload the file plus the kickstart.php file
I will include a link to both files - this may take me 1 hour depending on upload speed
You would then load the kickstart.php file in the browser
http://docs.joomlabamboo.com/joomla-templates/profilr-documentation
In case you've not found these yet - while you are waiting
Hi Again,
I just sent you an email with links to my personal dropbox folder
Before installation create an empty database as you will need these details for the kickstart installation process
It is nearly 3am here now so I will be signing off shortly - I've got another 20 mins
Cheers
Paul
thank you so much, England?
Yep
email arrived?
paulus1031 No, alas.
I just thought I'd check to see that you were able to download and install ok?
Paul
filmhdvideo I kept getting a sort of time out trying to upload the latest Ascent2 template from Joomlabamboo (5mb). I was on this forum looking for someone with similar experience with the ftp/extension manager route. Just before trying this thought I would swap browser from Google Chrome to Microsoft Edge. It loaded like a flash!
Absolutely. I'm sticking with Microsoft Edge browser for all uploads now.
Edge isn't bad at all but I prefer the developer tools on chrome
I think Edge is quicker and less memory leaks
Cheers
Paul
paulus1031 'Fewer.' Not 'less.'
The Peasants' Revolt of 1381
They certainly wanted less taxation
Cheers
Paul
