Hi, i've this problem on my site the Title that is Mo >> App Theme as you can see from the link http://www.vesuvioperajazz.com/ how to change it? I checked on the template, pages, menus and other... but nothing!
antonios30 I've this problem on my site the Title that is Mo >> App Theme as you can see from the link http://www.vesuvioperajazz.com/ how to change it?
Can you kindly post screenshot marked with annotations as to which title you wish to refer to as I am unable to see any such title as mentioned by you
Your website title may be changed in Template Options -> SEO tab. You can also disable this buil-in SEO options if you are using 3rd party seo plugin: https://www.gavick.com/documentation/wordpress/gavernwp-framework/seo-settings
Cheers Joshua
