Ninja Lead Moderator
Ninja Lead
- November 2014
- 3854 times in 3563 posts
September 29, 2015 at 4:12 am #693466Hi,
I can’t produce that bug at my end. I checked on your site and did not see the duplicate article on that, how can I see that problem on your site?
- November 2014
September 29, 2015 at 4:12 am #750010Hi,
giusti2 Friendgiusti2
- August 2012
October 11, 2015 at 8:50 am #704315<em>@Ninja Lead 492845 wrote:</em><blockquote>Hi,
You can add below css to remove the line source:
.item-page .content-links {
display: none;
into templates/ja_wall/css/template-j30.css file
About the second and third questions you can give me the URL to see this bug, I will check it further.
Regards</blockquote>
Hello Ninja. I use the social feed plugin with the Teline V template and have the same problem with the double image issue. Can you maybe tell me where I have to copy the css style?
- August 2012
October 11, 2015 at 8:50 am #751253<em>@Ninja Lead 492845 wrote:</em><blockquote>Hi,
display: none;
- November 2014
October 12, 2015 at 3:05 am #704481Which area are you referring to on your site? Things at least look to be running smoothly from what I can see.
- November 2014
October 12, 2015 at 3:05 am #751297Which area are you referring to on your site? Things at least look to be running smoothly from what I can see.
- August 2012
October 12, 2015 at 6:44 am #704557<em>@Ninja Lead 496890 wrote:</em><blockquote>Which area are you referring to on your site? Things at least look to be running smoothly from what I can see.</blockquote>
- August 2012
October 12, 2015 at 6:44 am #751329<em>@Ninja Lead 496890 wrote:</em><blockquote>Which area are you referring to on your site? Things at least look to be running smoothly from what I can see.</blockquote>
- November 2014
October 12, 2015 at 6:50 am #704558This way will help you out
Open templates/ja_teline_v/css/custom.css file and add new css style
.article-full.has-article-tools .article-content-main img {
display: none;
}Ninja Lead ModeratorNinja Lead
- November 2014
October 12, 2015 at 6:50 am #751330This way will help you out
display: none;
}giusti2 Friendgiusti2
- August 2012
October 12, 2015 at 12:06 pm #704671<em>@Ninja Lead 496928 wrote:</em><blockquote>This way will help you out
display: none;
</blockquote>It works on the articles … thanks, but when I see the frontpage, the I see also a part of the second image. Can I resolve this problem to?
- August 2012
October 12, 2015 at 12:06 pm #751393<em>@Ninja Lead 496928 wrote:</em><blockquote>This way will help you out
display: none;
- November 2014
October 13, 2015 at 2:17 am #704739Other places are showing duplicate image, you can add css style below into custom.css file
img.facebook-img.ja-social-img {
display: none;
}It will fix the problem on your site.
- November 2014
October 13, 2015 at 2:17 am #751461Other places are showing duplicate image, you can add css style below into custom.css file
display: none;
- August 2012
October 13, 2015 at 6:46 am #704771<em>@Ninja Lead 497102 wrote:</em><blockquote>Other places are showing duplicate image, you can add css style below into custom.css file
display: none;
}It will fix the problem on your site.</blockquote>
Thanky you Ninja. It works … now I have just 2 more things … I would like to disable the source link (Source Facebook) to and how can I show the article in a normal way and not with “quotes”. Thank you very much for your help.
This topic contains 41 replies, has 2 voices, and was last updated by Ninja Lead 9 years, 1 month ago.
