November 20, 2011 at 12:11 pm #170872
I’ve a few small issues that I need to clear on the site http://www.jwp.uk.com
1. The twitter icon in the JA ‘Our Social Profiles’ has decided that it doesn’t like being in front of the link like the other icons and that it would prefer to sit on top of it instead!
2. The map (JA Google) has decided to stop showing the accurate positition on the Contact page.
Any ideas?
Cheers
pavit Moderatorpavit
November 20, 2011 at 5:00 pm #425499Hi luds
<blockquote>1. The twitter icon in the JA ‘Our Social Profiles’ has decided that it doesn’t like being in front of the link like the other icons and that it would prefer to sit on top of it instead!</blockquote>
go to /modules/mod_jatwitter/assets/style.css at line 2 now you have
.twitter {
padding: 15px 0 !important;
}change to
.twitter {
padding: 15px 10 !important;
}<blockquote>2. The map (JA Google) has decided to stop showing the accurate positition on the Contact page.</blockquote>
i cannot check your configuration, the first thing i can suppose are the wrong Lat and Long details try to check better.
November 20, 2011 at 7:08 pm #425527Hi
Twitter one fixed 🙂
THanks!
I’ve put checked the latitude and longtitude. It just doesn’t seem to to like it! It’s about a mile and a half out! Don’t know whether it’s related but it also isn’t taking the dimensions specified in the plugin either.
November 20, 2011 at 7:17 pm #425528Just one idea about it
Have you cleaned your jat3 cache ?
November 20, 2011 at 8:01 pm #425536Cleared jat3 and joomla cache several times
November 20, 2011 at 8:04 pm #425539Ok i cannot be more helpful with these info, i need to login in your backend to check the plugin config
If for you is not a problem maybe you can update this thread at position 1 with your admin account details
November 20, 2011 at 10:18 pm #425580cheers
have updated no.1 with the details 🙂
November 20, 2011 at 10:56 pm #425593Hi i have checked your plugin updated it to the last version and nothing change
try to do in this way uninstall and reinstall again the plugin with these info in the target location “3, Cromer Road,Southport, Merseyside,PR8 2NH.” the older was wrong
November 21, 2011 at 11:04 am #425675I can’t find the plugin file. PLease could I have a link where I can download it?
This topic contains 11 replies, has 2 voices, and was last updated by luds 12 years, 12 months ago.
