  • garciad Friend
    #131511
    Hi, I’m glad with my recently buyed membership. I build a site with JA Teline II, but I have an issue with “Hot Topic” module. It shows the picture but the transparent blue box doesn’t move and doesn’t show the text.
    I want to know too, How can I always show Icons in my Main menu (The top menu), because I’ve set to show icons but nothing happens.
    The other thing is I want to make the place where is the date, so the flags of translations can stay in the same line as day, search, and Bookmark Us.
    One more: If you look at a little banner in the right column (called CXO Community), you can see behind it, that are two lines separators (one is for the IUPFA banner, and the other for the Ayudanos! banner), but this lines are together and not showing like they have.
    You can see all this issues in http://www.secuprof.com.ar
    Thanks to all how can help, I’m really glad with my brand new site!
    Menalto Friend
    #269370
    Did you manage to get this solved? If you did please mark this as solved, in not reply here and we will try to help you out.
    felsimedia Friend
    #270340
    Seem solved
This topic contains 3 replies, has 3 voices, and was last updated by  felsimedia 16 years, 3 months ago.
