  • arkfeld Friend
    #127336
    Some of your templates are not bug free – like the JA Barite form. I would suggest you remove it until it is ready for prrime time. I think your site gets a bad name when you release templates before they work. It is NOT easy to work with templates that have bugs.
    alicia Friend
    #245352
    If that were the case there wouldn’t be many templates posted.
    Just beware when bugs are fixed… If they remove something that was a part of the template in the bug fix… Hung says its custom work to get it back again… So all I say is before you put alot of time in something that has bugs in it, beware…. it may all be for nothing.
    kashxo Friend
    #245392
    Our templates was tested for bugs free before release. The version you’ve seen on demo is bugs free at our test result.
    The fact is, templates can not (and never) avoid bugs while using along with other extensions or being customized. We are incresing supporters and developers around forums to help users solve their bugs and issue while building their site with our templates.
    Please feel free and don’t hesitate to post your questions/problems/issues on our forums. We will trying to help you solve them or get them fixed in our package.
This topic contains 3 replies, has 3 voices, and was last updated by  kashxo 16 years, 7 months ago.
