  • cirymarr Friend
    #180515
    I have built a nice eCommerce site with JA Lens and VirtueMart 2. Overall, I love the look and feel of this responsive template, but I have a few issues – hopefully someone may be able to help:
    The site is here: http://novero.ie/index.php/shop
    1. On my Main Menu, I have 2 menu levels deep (see the SHOP dropdown, as an example) – all works well on desktop browsers, but on an iPhone, the “sub menu” level doesn’t display properly, it simply highlights the item that displays the sub menu, as well as highlighting all of these sub menu items. As a result, menu navigation is next to impossible on an iPhone – I can’t upload a screenshot to demonstrate, but anyone out there with an iPhone should be able to replicate this.
    2. I am using the built in Slideshow mpodule on the homepage, http://www.novero.ie – however, if you then select any item from either the Category dropdown menu, or select either Linear or Grid Layout, nothing changes – the slideshow still appears (possibly in front of everything else) – The only way currently, that I can display the categories on http://www.novero.ie is by selecting SHOP from the top menu – this is confusing for visitors to the site.
    3. Lastly, (this may be a VirtueMart issue, but I don’t know) – If you select an item from the SHOP on http://www.novero.ie and then ADD TO CART – you will see the shopping cart page – On this screen, there is a link “Click here to read terms of service…” – when you click this link, the Terms are not displayed – the screen just “darkens” a bit – I really need to get this working.
    Any help with any of these issues would be greatly appreciated.
    Stork11 Friend
    #466471
    Hello cirymarr,
    1. JA Lens doesn’t support 2nd level menu, so you can’t do anything like that.
    2. Category filter module is only used categories layout (the layout is displayed when you click on “Shop” menu).
    3. Please send me a link where problem occurs. I can’t find it on your site.
    Regards.
    cirymarr Friend
    #466649
    Re number 3 – on the following link, click “Click here to read terms of service…” http://www.novero.ie/index.php/component/virtuemart/cart?Itemid=0
    Stork11 Friend
    #466730
    <em>@cirymarr 337687 wrote:</em><blockquote>Re number 3 – on the following link, click “Click here to read terms of service…” http://www.novero.ie/index.php/component/virtuemart/cart?Itemid=0</blockquote>
    Hello cirymarr,
    Please add following style into “/templates/ja_lens/css/template.css” file:
    #facebox .popup {display: block !important;}
    Hope this help.
    Regards.
    cirymarr Friend
    #466955
    Thanks for that – that seems to work.
This topic contains 5 replies, has 2 voices, and was last updated by  cirymarr 12 years, 4 months ago.
