  • Excalibur! Friend
    #127804
    I’m testing this great template on my computer true localhost (VertigoServ).
    1. When I install template (not quickstart) I got a blank screen… but template is installed.
    2. When I want to publish JA News & JA News Frontpage I can not find JA News position (only jazin1 to jazin5). There’s no also JA Login…
    3. When I want to edit setting inside JA Section menu plugin I got this screen:
    4. I tried to install quickstart on my test server and I noticed a slow performance issue…
    5. Also on test server I got this issue:
    vidanet Friend
    #246455
    Hi I’ve the same problem and I see also this error:
    <em>@NeoDynamic 49994 wrote:</em><blockquote>I’m testing this great template on my computer true localhost (VertigoServ).
    </blockquote>
    soundbeat Friend
    #246478
    Got the same problems also!!!
    #246491
    1.Blank screen: plz enable gd2 extension in PHP
    2.You can add those positions in templateDetails.xml
    <position>ja-news</position>
    <position>ja-login</position>
    Add those lines between <positions> and </positions>
    3. You can read my post HERE
    Excalibur! Friend
    #246556
    Tnx nguoiabcd for your reply…
    1. I have enabled gd2 extension in PHP.
    2. Tnx!
    3. Tnx! It works! It seems that performance is better also…
    I still have problems from my first post (#1 & #3) and now I have a new one: when I publish JA News & JA News Frontpage (on virtual server) I got this:
    Menalto Friend
    #246590
    It seems that the css file isnt with then, can you right click and View sorce and see if you can see template.css or template_css.css mentioned there`?
    Excalibur! Friend
    #246592
    Yes, there’s not a CSS, but only when I publish JA News 1.3.0.
    Menalto Friend
    #246597
    Open up the index.php file and find this:
    <link rel="stylesheet" href="<?php echo $tmpTools->templateurl(); ?>/css/template.css" type="text/css" />
    And replace with this:
    <link rel="stylesheet" href="http://www.yoururl.com/templates/ja_teline_ii/css/template.css" type="text/css" />
    See if it works then
    Excalibur! Friend
    #246602
    <em>@Menalto 50182 wrote:</em><blockquote>
    See if it works then</blockquote>
    Unfortunately there’s no change…
    Excalibur! Friend
    #246606
    I found that that apears when I have Joomla SEO enabled, but when I disable SEO I got blank page… I tried to enter code from here, but blank page is still there…
    #246638
    I have fixed it HERE
    Plz try follow it
    Hope can help you
    Excalibur! Friend
    #246693
    Yes I tried that before and didn’t help… (my last post).
    I’ll try today on my live test server… I will install new Joomla 1.5.3 and than install JA Teline II (with all new updates) without enabling SEO…
    Excalibur! Friend
    #246705
    I installed Joomla 1.5.3 on my test server then I installed JA Teline II (with all new updates) without SEO and everything is working fine… :confused: then I enabled SEO and everything is ok… uh…
    Excalibur! Friend
    #246721
    Interesting… in Joomla 1.5.3 everything is working (on virtual nad test server) except problem #3 (First post) on virtual server…
    I found also that nothing appears in JA News Frontpage when I choose headline_fp.php (Number of Featured Articles are 5). Any idea?
    raymondorta Friend
    #251380
    I have the same slow performance issue.
    Any answer for this trouble ??
This topic contains 15 replies, has 6 voices, and was last updated by  raymondorta 16 years, 6 months ago.
