  • milatovar Friend
    #160959
    Trying to validate my website I got 211 errors and 152 warnings!!!!
    Please, could you tell me where to start to fix this???? It seems a very daunting task.
    Thank You.
    My website is: http://www.pivotmag.net
    It cannot be complete until it’s properly validated!
    Ninja Lead Moderator
    #379612
    may I just ask, have you modified the template?
    milatovar Friend
    #379652
    Yes, I’ve changed it quite a lot. And, as I’m totally new at this, I had no idea of all the problems I may have!!!!
    The thing is that it can be seen ok in all browsers I’ve checked out but I’d be very grateful to receive some help on how to fix this now. I know I must correct every error manually. That’s fine, but where do I exactly change the code?
    Any advice, suggestion, help would be very much appreciated.
    Thanks,
    #379753
    when you validate your site, through w3.org, it will list every issue you have, according to that, fix the issues one by one.
    http://validator.w3.org/check?uri=http://www.pivotmag.net&charset=(detect+automatically)&doctype=Inline&group=0&user-agent=W3C_Validator/1.2
    you might also need to study a little about xhtml standard.
This topic contains 4 replies, has 2 voices, and was last updated by  Ninja Lead 13 years, 10 months ago.
