sfpkent Friend
sfpkent
- October 2008
- 75 times in 1 posts
January 2, 2010 at 2:05 pm #147249Hi,
I believe JA Team should fix it. There are a lot of problem for IE 8.
Please view my website – http://worldwebcreator.com
Attached with image file.
Thanks!
Kent- Saguaros Moderator
January 4, 2010 at 4:25 am #328061Hello guy!
Please fix the problem as following:
1) open the file /templates/ja_coopper/index.php and find codes at line 61:
[PHP]
<style type=”text/css”>
.clearfix {display: inline-block;}
</style>
[/PHP]
replace:
[PHP]
.clearfix {display: block;}
</style>
</style>
[/PHP]
After you make done, i ‘ll check and fix others.Thanks
sfpkent Friendsfpkent
- October 2008
January 4, 2010 at 4:34 am #328064Done, you can view it now, but the logo stil has problem.
Saguaros ModeratorSaguaros
January 4, 2010 at 5:03 am #328070Hello guy!
Please open the file templates/ja_cooper_business/css/template.css file and find codes at line 822
#ja-header-innerpad {
background: url(../images/header-bg.gif) no-repeat center top;
height: 100px;
padding: 0 10px;
line-height: normal;
}replace
height: 100px;
}1 user says Thank You to Saguaros for this useful post
- October 2008
January 4, 2010 at 7:07 am #328091Thank you very much, so far so good! 🙂
But there is another problem, the USER9 is not align with the right module. Kindly refer to the attachment.
Here is my site again – http://worldwebcreator.com
ok in Firefox but not ok in IE 8.
January 6, 2010 at 2:36 am #328349Hello guy!
Please open the file /templates/ja_cooper_business/css/ie.css find remove codes
1) at line 206:#ja-container-innerpad {
width: 100%;
}2) at line 219
width: 99%;}
Goodluck
- October 2008
January 6, 2010 at 2:57 am #328353There is no such file in css folder friend!
January 6, 2010 at 2:58 am #328355Oh i’m sorry, here is the link: http://worldwebcreator.com/templates/ja_cooper_business/css/ie.php
- October 2008
January 6, 2010 at 8:29 am #328394Thanks, it work perfectly! 🙂
AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 2 voices, and was last updated by sfpkent 14 years, 9 months ago.
A lot of problem for IE 8
