May 12, 2015 at 5:40 am #206277
Hello! There is a problem with the site layout in IE 11.
There is a server windows 2012 server standart with IE 11. When I browse the site from a computer with Windows 7 and Windows 8.x with IE 11, the megamenu is not displayed and content position displayed is incorrect, some icons of not shown. Use a quickstart with a template purity III.No additional extensions are not installed. Any modifications to the source plug-in is not present and no modifications to the code pattern is not present.
Web server WAMP
The local server, no access to the interent. but the ability to connect remotely over the Internet via teamviewer.
Other browsers do not have these problems.
Bad:
Good:
- Saguaros Moderator
May 13, 2015 at 2:43 am #570389Hi there,
This issue in IE is often caused by one of these reasons:
Limitation in number of loaded files in IE browser:
IE often limits the number of css files loaded and cause this kind of issue. You can try enabling the ‘Optimize CSS’ option in template manager section in backend and see how it goes.Conflict / errors
If there is no go, you can inspect element of your site (by clicking the F12 button on keyboard) and check the ‘Console’ tab and see whether there is any error or not. Sometime there is conflict between 3rd party extension installed and megamenu of template.Saguaros ModeratorSaguaros
May 13, 2015 at 2:43 am #735455Hi there,
If there is no go, you can inspect element of your site (by clicking the F12 button on keyboard) and check the ‘Console’ tab and see whether there is any error or not. Sometime there is conflict between 3rd party extension installed and megamenu of template.May 13, 2015 at 1:28 pm #570452Bootstrap error
How to fix this error or disable this option? May be some of php extension or apache extension must be enabled/disabled?3rd party extension not installed
the ‘Optimize CSS’ option enabled. trying both variant (on/off), and ‘Optimize JS’ option too
May 13, 2015 at 1:28 pm #735516Bootstrap error
May 14, 2015 at 3:39 am #570497which version of Joomla and PHP version are you using?
May 14, 2015 at 2:35 pm #570557php-5.3.10-Win32-VC9-x86
apache-2.2.20-win32-x86-openssl-0.9.8r
joomla 3.4.1
May 15, 2015 at 7:35 am #570635Did you try to switch to PHP 5.4 or above?
May 15, 2015 at 7:35 am #735698Did you try to switch to PHP 5.4 or above?
May 15, 2015 at 10:08 am #570665yes. php 5.4, 5.5, 5.6, apache 2.4
May 15, 2015 at 10:08 am #735728yes. php 5.4, 5.5, 5.6, apache 2.4
May 18, 2015 at 6:15 am #570869You can put your site online and PM me URL, admin & ftp account of your site. I would need a closer look to check this issue for you
May 18, 2015 at 6:15 am #735931You can put your site online and PM me URL, admin & ftp account of your site. I would need a closer look to check this issue for you
June 16, 2015 at 3:34 pm #574254Did you resolve this issue? I’m having the same problem.
See attached photo for detail of error found in IE Console.
Line 459: if(this.$element[0]instanceof document.constructor&&!this.options.selector){throw new Error(‘`selector` option must be specified when initializing ‘+this.type+’ on the window.document object!’)}
Error msg:
Invalid operand to ‘instanceof’: Function expected
June 17, 2015 at 1:44 am #574324Do you have any 3rd party extension installed on your site? Pls try to disable them first.
AuthorPostsThis topic contains 21 replies, has 4 voices, and was last updated by bmens 9 years, 5 months ago.
