  • metdick Friend
    #148829
    Good afternoon everybody
    I have a problem which seems to be template ralated:
    situation: 1.5.15, Zeolite, JCE-editor 1.5.6, JCE-plugin 1.5.7
    In a content article I want to create an image roll-over with JCE
    When I save the article the code (onmouseover, onmouseout) is stripped
    OK.. no problem, I thought: I will disable the JCE editor and paste the code in the html-editor
    And… The code is stripped too!!!
    When I use a rollover in a custom html module… using JCE… the code isn’t stripped.
    I assumed this would be a JCE issue
    BUT: another site, with exactly the same situation: 1.5.15, JCE-editor 1.5.6, JCE-plugin 1.5.7
    but with another (commercial) template does not give this problem.
    Anybody here with help and advice?
    Dick
    Hello guy
    i think that problem is from the setting of editor and global component setting, you try to compare and configure same as the another site
    if possible, Can you pls give me the link to your site and the administrator account.
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 10 months ago.
