  • bijvoet Friend
    #128891
    When the access level of a sub items in a menu is “special” and a vistitor has logged in as “registered”, this sub-item is hidden in the left main menu, but does show in the horizontal menu.
    Is this a bug in Joomla or in Ja Purity?
    See:
    http://www.imsonline.nl/content/
    The link TEST Auhorization at the left and in the horizontal menu show “public” as submenu-item.
    Log in with username = guest and password = guest.
    The link TEST Auhorization at the left shows “public” and “registered” as submenu items,
    But the horizontal menu shows “public”, “registered” AND “special” as submenu items.
    When you login with specialguest / specialguest than you will see all submenu items.
    Please feedback
    Alwin
    Menalto Friend
    #269343
    Did you manage to get this solved? If you did please mark this as solved, in not reply here and we will try to help you out.
    bijvoet Friend
    #269913
    Thanks for your resction.
    No, this roblem has nit been solved yet.
    Because I did not get any reactions I removed the links mentioned in my request.
    The Access level problem still exists.
    Looking forward to you assistance in this matter.
    Bye
    Alwin
    alisandre Friend
    #289497
    Hi. I have created a site without left main menu, because i want use the horizontal of the JA Purity template. When i set the Special Access to one menu item this is seen by the Registered Users too. Excuse me for my bad English :p. Thank you. Alessandra.
This topic contains 4 replies, has 3 voices, and was last updated by  alisandre 15 years, 11 months ago.
