  • Creaktor Branding Agency Friend
    #1034743
    https://www.mijnmuziekles.nl/muziekdocenten
    there you see the header image being blank. it misses the / for the path.
    1. Schermafbeelding-2017-05-17-om-10.49.28
    www.creaktor.com
    Pankaj Sharma Moderator
    #1034753
    The site is in offline mode. Can u share the login details to check this issue?
    Also please make sure you are using latest version of JA Uber
    #1034758
    www.creaktor.com
    #1034891
    Can u try the style-2 real file for the acm slideshow
    I noticed you are using a custom file that does not update on template updates.
    I tested a copy of module and it works fine.
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 6 months ago.
