  • webdojo Friend
    #999268
    Hi there,
    i have some troubles with the acm "news featured" type modules: it’ seems like those kind of modules incorporates others similar modules. In this case the "carousel" variant inherit the module class suffix from the module on top of it wich has the "slide items" style. In the code the first module seems to contain the second. This doesn’t happen on other site whit the same layout, and same version of joomla. Can’t figured out why this happens on a fresh installation.
    http://nonnoboi.it/
    Ty in andvance
    Pankaj Sharma Moderator
    #999404
    At this item your site Homepage is looks fine.
    Kindly provide me module name, screenshot of the problem that you are getting and Page URL.
    So that i can check it for you.
    webdojo Friend
    #1005468
    Hi, sorry for the late answer!
    here the link: http://demo11.webdojo.it/. The module is a "News Featured : event-slider" type called "event rizzotti". As you can see in the screenshot, the module seems to force his style to the modules under it.
    Thank you in advance
    1. screen
    #1005475
    This module > http://prntscr.com/e06f3h
    Its designed i this way as on your site, it is normal and looks nice. What you want to change in the module?
    webdojo Friend
    #1006799
    I would like to maintain the default style of the second module, the module "News" has a default lite background
    #1006800
    What background you want to add, it would be helpful if you give me a screenshot and point the changes.
    webdojo Friend
    #1006965
    Hi there,
    i solve the problem creating a custom class for the "news" module. I left a screenshot of the result. But this is a partial solution because by default the module "events" keep incorporates oder modules. For example, if i move the "events" module on top of my home the whole page turn black. I think this is a html structure problem. Hope my explanation was clear.
    Thank you
    1. screen2
    #1006975
    thanks for sharing, It also helps other user for same topics.
This topic contains 7 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 10 months ago.
