  • foolevil Friend
    #982035
    I updated Joomla to 3.6.4 and everything went fine, except when client (or me) try to edit medu list of the week from front end, after save & close module goes all off. What seems to happen, Joomla somehow turns module position to "none", and so the module turns invisible. It happens as editor and superuser rights. This goes totally over my level… help. Thank You!
    note: the module is currently named "Viikon 44 ruokalista" (in finnish, we change the name every week).
    Tor Friend
    #982099
    Hello, i have the same problem with several modules, I use Uber template. The position goes blank when saved from front end. Webpage is http://josygaard.no
    Also after i updated Joomla to 3.6.4
    Tor Hølleland
    Nye nettsider - hjemmesider
    https://atlanta.no
    This template is not ready for J3.6.4, I’ve reported this to the team for further checking when updating template to this latest version of Joomla.
This topic contains 2 replies, has 3 voices, and was last updated by  Saguaros 8 years, 1 month ago.
