  • Pankaj Sharma Moderator
    #986028
    Did you sort it out ?
    I can see the testimonial module author name having an href with #link on your site .
    Here : http://prntscr.com/d6zf4l
    Kindly check and update me if still there is any issue .
    webdojo Friend
    #986199
    Hi there, i think you missed the problem: i can insert an href but, when i do so, part of the code become visible. Down below the screenshot
    Ty
    1. href
    #986208
    webdojo Friend
    #986867
    #986886
    the issue is because the image alt tag picks the same value from the author name . I just removed it from the acm file , now you can see its working fine .
    webdojo Friend
    #986937
    Thanks a lot for your help!
This topic contains 6 replies, has 2 voices, and was last updated by  webdojo 8 years ago.
The topic ‘acm Statistics : style-1 | acm Testimonials : style-1 ( href problem )’ is closed to new replies.
