  • fiumeciane Friend
    #167828
    Something has changed in view of the button “Add comment”.
    1) As you can see infigure # 1, to the left of the word “Add” you see an icon not seen that before.
    Figure #1
    2) When you put your mouse pointer over the word “Add comment”, it disappears! (Figure #2)
    Figure #2
    Help me please?
    1. addcomments
    2. addcomments1
    khoand Friend
    #408696
    Could you give me a link to your website?
    fiumeciane Friend
    #408713
    Here it is
    To see “Add Comment” button this is one of the links
    khoand Friend
    #408739
    I find down your problem is caused by this code
    .jac-add-button a:hover, .jac-add-button a:active, .jac-add-button a:focus {
    background: black;
    color: white !important;
    border: 1px solid black;
    text-decoration: none;
    You just remove bold line, but I don’t know where file contain it. Because cache mode turns off.
    fiumeciane Friend
    #408762
    ok khoand, but how can I find that file?
    khoand Friend
    #408776
    You must turn cache off by login backend > Extensions > template manager > your_template > Global tab > set Optimize CSS is No.
    After you do it, you inform me, please
    fiumeciane Friend
    #408894
    I did, then I emptied the cache of Joomla, that of the T3, I emptied the temporary files, the cache of the browser (IE8 Fireox, Opera, Chrome): nothing changes. The problem remains.
    Manos Moderator
    #408898
    You have to go to template.css file and you can find
    it’s around line 1053
    Then you have to find the color setting ( color: #FFFFFF !important; ) and change to whatever color you like!
    ( i suggest : color: FF0000 !important; )
    Manos
    fiumeciane Friend
    #409099
    Thanks Manos, now it works. I sent you a PM, please read it.
This topic contains 9 replies, has 3 voices, and was last updated by  fiumeciane 13 years, 4 months ago.
