December 5, 2010 at 11:09 pm #157094
I am trying to add a module for a shopping basket at the right top of de header.
Just above the slide show, i jus dont manage to do that. Can anyone help with this one.Thanks in advance
Bert
Sherlock FriendSherlock
- 2478 times in 2162 posts
December 7, 2010 at 8:47 am #365570Dear hoekstrab,
You can try as following
1) copy the file of pluginssystemjat3base-themesdefaultblocksheader.php to the folder templatesja_droidblocks2) Open the copied file, add following line of code at the bottom of the file
<jdoc:include type=”module” name=”your_module_name” />
You may need to add some css rules to get your module fit the position.
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by Sherlock 13 years, 11 months ago.
Add module for for shopping basket on the right top
