February 16, 2010 at 11:31 pm #148731
Hey everyone.
I’m looking to add a new module position right above (inside) the content area.
I’ve tried adding this
<?php if($this->countModules(‘bannerimage’)) : ?>
<jdoc:include type=”modules” name=”bannerimage” />
<?php endif; ?>to various places inside of index.php but I always end up adding it above the content area, but also above the right/left columns. I’d like to add this position so that it doesn’t push down the menu I have published to the right column position.
Any suggestions? I’d greatly apprecaite it, folks!
David
- 2008 times in 1700 posts
February 24, 2010 at 7:45 pm #333759Hi DreamWeb
Could you send me the code of templates/ja_nickel/index.php file so that i could have a closer look on the issue?
February 24, 2010 at 8:43 pm #333765Thanks for getting back to me. I’ve embedded the index.php as it currently stands on our website (we have modified it a little bit).
David
<?php
# JA Nickel for Joomla 1.5.x - Version 1.0 - Licence Owner JA9208
# Copyright (C) 2004-2008 J.O.O.M Solutions Co., Ltd. All Rights Reserved.
# @license - Copyrighted Commercial Software
# Author: J.O.O.M Solutions Co., Ltd
# Websites: http://www.joomlart.com - http://www.joomlancers.com
# This file may not be redistributed in whole or significant part.
-------------------------------------------------------------------------*/// no direct access
defined( '_JEXEC' ) or die( 'Restricted access' );include_once (dirname(__FILE__).DS.'ja_vars_1.5.php');
?><?php
defined('_JEXEC') or die('Restricted access');
JHTML::_('behavior.mootools');
$this->baseurl = JURI::base();
?><?php
// no direct access
defined( '_JEXEC' ) or die( 'Restricted index access' );
define( 'YOURBASEPATH', dirname(__FILE__) );
require( YOURBASEPATH.DS."styles.php");
require( YOURBASEPATH.DS."rt_styleswitcher.php");
JHTML::_( 'behavior.mootools' );
global $template_real_width, $leftcolumn_width, $rightcolumn_width, $tstyle;
global $js_compatibility, $menu_rows_per_column, $menu_columns, $menu_multicollevel;
global $header_style, $body_style, $menu_name;
global $f_enablejs, $f_enable_current, $f_subsoffset_top, $f_subsoffset_left, $f_vertical_animation;
global $f_vertical_duration, $f_horizontal_animation, $f_horizontal_duration, $sm_enable_current;$live_site = $mainframe->getCfg('live_site');
$template_path = $this->baseurl . '/templates/' . $this->template;$preset_style = $this->params->get("presetStyle", "style1");
$header_style = $this->params->get("headerStyle", "style1");
$body_style = $this->params->get("bodyStyle", "light");$frontpage_component = $this->params->get("enableFrontpage", "show");
$enable_ie6warn = ($this->params->get("enableIe6warn", 0) == 0)?"false":"true";
$font_family = $this->params->get("fontFamily", "optima");
$enable_fontspans = ($this->params->get("enableFontspans", 1) == 0)?"false":"true";
$enable_inputstyle = ($this->params->get("enableInputstyle", 1) == 0)?"false":"true";
$inputs_exclusion = $this->params->get("inputsExclusion", "'.content_vote'");$template_width = $this->params->get("templateWidth", "982");
$leftcolumn_width = $this->params->get("leftcolumnWidth", "260");
$rightcolumn_width = $this->params->get("rightcolumnWidth", "260");
$leftinset_width = $this->params->get("leftinsetWidth", "180");
$rightinset_width = $this->params->get("rightinsetWidth", "180");
$splitmenu_col = $this->params->get("splitmenuCol", "rightcol");
$menu_name = $this->params->get("menuName", "mainmenu");
$menu_type = $this->params->get("menuType", "fusion");
$default_font = $this->params->get("defaultFont", "default");
$show_logo = ($this->params->get("showLogo", 1) == 0)?"false":"true";
$show_textsizer = ($this->params->get("showTextsizer", 1) == 0)?"false":"true";
$show_date = ($this->params->get("showDate", 0) == 0)?"false":"true";
$clientside_date = ($this->params->get("clientSideDate", 0) == 0)?"false":"true";
$show_topbutton = ($this->params->get("showTopbutton", 1) == 0)?"false":"true";
$show_copyright = ($this->params->get("showCopyright", 1) == 0)?"false":"true";
$copyright_text = $this->params->get("copyrightText", "Copyright 2009, All Rights Reserved");
$js_compatibility = ($this->params->get("jsCompatibility", 0) == 0)?"false":"true";// fusion menu
$f_enablejs = ($this->params->get('roknavmenu_fusion_enable_js', 1) == 0)?"false":"true";
$f_opacity = $this->params->get('roknavmenu_fusion_opacity', 1);
$f_effect = $this->params->get('roknavmenu_fusion_effect', 'slidefade');
$f_hidedelay = $this->params->get('roknavmenu_fusion_hidedelay', 500);
$f_menu_animation = $this->params->get('roknavmenu_fusion_menu_animation', 'Quad.easeOut');
$f_menu_duration = $this->params->get('roknavmenu_fusion_menu_duration', 400);
$f_pill = $this->params->get('roknavmenu_fusion_pill', 0);
$f_pill_animation = $this->params->get('roknavmenu_fusion_pill_animation', 'Back.easeOut');
$f_pill_duration = $this->params->get('roknavmenu_fusion_pill_duration', 400 );
$f_tweakInitial_x = $this->params->get('roknavmenu_fusion_tweakInitial_x', '0');
$f_tweakInitial_y = $this->params->get('roknavmenu_fusion_tweakInitial_y', '0');
$f_tweakSubsequent_x = $this->params->get('roknavmenu_fusion_tweakSubsequent_x', '0');
$f_tweakSubsequent_y = $this->params->get('roknavmenu_fusion_tweakSubsequent_y', '0');
$f_enable_current = ($this->params->get('roknavmenu_fusion_enable_current_id', 0) == 0)?"false":"true";// splitmenu
$sm_enable_current = ($this->params->get('roknavmenu_splitmenu_enable_current_id', 0) == 0)?"false":"true";require(YOURBASEPATH . "/rt_styleloader.php");
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="<?php echo $this->language; ?>" lang="<?php echo $this->language; ?>"><head>
<jdoc:include type="head" />
<?php JHTML::_('behavior.mootools'); ?>
<link rel="stylesheet" href="<?php echo $tmpTools->baseurl(); ?>templates/system/css/system.css" type="text/css" />
<link rel="stylesheet" href="<?php echo $tmpTools->baseurl(); ?>templates/system/css/general.css" type="text/css" /><link rel="stylesheet" href="<?php echo $tmpTools->templateurl(); ?>/css/typo.css" type="text/css" />
<script language="javascript" type="text/javascript" src="<?php echo $tmpTools->templateurl(); ?>/js/ja.script.js"></script>
<?php if ($tmpTools->getParam('ja_cufon')) : ?>
<script language="javascript" type="text/javascript" src="<?php echo $tmpTools->templateurl(); ?>/js/cufon/cufon.js"></script>
<script language="javascript" type="text/javascript" src="<?php echo $tmpTools->templateurl(); ?>/js/cufon/Zrnic_400.font.js"></script>
Cufon.replace('.componentheading, .contentheading, div.moduletable h3, div.moduletable_menu h3, div.moduletable_text h3,div.moduletable_highlight h3', { fontFamily: 'Zrnic' });
</script>
<?php endif; ?>
<?php if ($tmpTools->getParam('usertool_modfunc')) : ?>
<script language="javascript" type="text/javascript">
var siteurl = '<?php echo $tmpTools->baseurl();?>';
var tmplurl = '<?php echo $tmpTools->templateurl();?>';
</script><?php endif; ?>
<!-- Menu head -->
<?php if ($jamenu) { $jamenu->genMenuHead(); } ?>
<link rel="stylesheet" href="<?php echo $tmpTools->templateurl(); ?>/css/addons.css" type="text/css" />
<link rel="stylesheet" href="<?php echo $tmpTools->templateurl(); ?>/css/template.css" type="text/css" />
<link rel="stylesheet" href="<?php echo $tmpTools->templateurl(); ?>/css/ja.bulletin.css" type="text/css" />
</script>
<link href="<?php echo $tmpTools->templateurl(); ?>/css/colors/<?php echo strtolower ($tmpTools->getParam(JA_TOOL_COLOR)); ?>.css" rel="stylesheet" type="text/css" />
<?php if ($tmpTools->isIE()) { ?>
<link href="<?php echo $tmpTools->templateurl(); ?>/css/ie.php" rel="stylesheet" type="text/css" />
<link href="<?php echo $tmpTools->templateurl(); ?>/css/colors/<?php echo strtolower ($tmpTools->getParam(JA_TOOL_COLOR)); ?>-ie.php" rel="stylesheet" type="text/css" />
window.addEvent ('load', makeTransBG);
function makeTransBG() {
makeTransBg($$('img'));
</script>
</script>
<?php }?><?php if ($tmpTools->isOP()) { ?>
<link href="<?php echo $tmpTools->templateurl(); ?>/css/op.css" rel="stylesheet" type="text/css" />
<?php } ?>
<?php
require(YOURBASEPATH . DS . "rt_utils.php");
require(YOURBASEPATH . DS . "rt_head_includes.php");
</head><body id="bd" class="<?php echo $tmpTools->getParam(JA_TOOL_LAYOUT);?> <?php echo $tmpTools->getParam(JA_TOOL_SCREEN);?> fs<?php echo $tmpTools->getParam(JA_TOOL_FONT);?>">
<a name="Top" id="Top"></a>
<!-- HEADER -->
<div id="ja-header" class="wrap">
<div class="main clearfix"><?php
$siteName = $tmpTools->sitename();
if ($tmpTools->getParam('logoType')=='image') { ?>
<h1 class="logo">
<a href="index.php" title="<?php echo $siteName; ?>"><span><?php echo $siteName; ?></span></a>
</h1>
<?php } else {
$logoText = (trim($tmpTools->getParam('logoText'))=='') ? $config->sitename : $tmpTools->getParam('logoText');
$sloganText = (trim($tmpTools->getParam('sloganText'))=='') ? JText::_('SITE SLOGAN') : $tmpTools->getParam('sloganText'); ?>
<div class="logo-text">
<p class="site-slogan"><?php echo $sloganText;?></p>
<h1>
<a href="index.php" title="<?php echo $siteName; ?>"><span><?php echo $logoText; ?></span></a>
</h1>
</div>
<?php } ?>
<?php if($this->countModules('ja-login')) : ?>
<div id="ja-headtools" class="ja-headtool">
<ul>
<jdoc:include type="modules" name="ja-login" />
</ul>
</div>
<?php endif; ?>
</div>
</div>
<!-- //HEADER --><!-- MAIN NAVIGATION -->
<div id="ja-mainnav" class="wrap">
<ul class="no-display">
<li><a href="<?php echo $tmpTools->getCurrentURL();?>#ja-content" title="<?php echo JText::_("Skip to content");?>"><?php echo JText::_("Skip to content");?></a></li>
</ul>
<div id="horiz-menu" class="<?php echo $mtype; ?>">
<div id="horizmenu-surround">
<?php echo $topnav; ?>
</div>
</div><?php if ($this->countModules('user4')) { ?>
<div id="ja-search">
<jdoc:include type="modules" name="user4" style="raw" />
</div>
<?php } ?>
</div>
</div>
<?php if ($hasSubnav) : ?>
<div id="ja-subnav" class="warp">
<?php if ($jamenu) $jamenu->genMenu (1,1); ?>
</div>
</div>
<?php endif; ?>
<!-- //MAIN NAVIGATION --><div id="ja-container<?php echo $divid; ?>" class="wrap">
<?php if ( $ja_left) { ?>
<!-- Left COLUMN -->
<div id="ja-col1">
<div class="ja-innerpad">
<jdoc:include type="modules" name="left" style="jamodule" />
</div>
</div>
<!-- //Left COLUMN -->
<?php } ?>
<!-- CONTENT -->
<div id="ja-content">
<jdoc:include type="message" />
<?php if ($this->countModules('ja-slideshow') ) { ?>
<!-- TOP SPOTLIGHT -->
<div id="ja-topsl" class="wrap">
<div class="main">
<div class="inner clearfix">
<div id="ja-slideshow">
<jdoc:include type="modules" name="ja-slideshow" style="raw" />
</div>
</div>
</div>
</div>
<!-- //TOP SPOTLIGHT -->
<?php } ?>
<div id="ja-current-content" class="clearfix">
<jdoc:include type="component" />
</div>
<?php if ( $ja_right): ?>
<div id="ja-col2">
<jdoc:include type="modules" name="right" style="jamodule" />
</div>
<?php endif; ?>
</div>
<!-- //CONTENT -->
</div></div>
</div>
<!-- PATHWAY -->
<div id="ja-pathway" class="wrap">
<div class="main">
<div class="ja-pathway-text">
<strong>You are here:</strong><jdoc:include type="module" name="breadcrumbs" />
</div>
</div>
</div>
<!-- //PATHWAY -->
<?php
$spotlight = array ('user6','user8','user9');
$bots2 = $tmpTools->calSpotlight ($spotlight,$tmpTools->isOP()?100:99.9);
if( $bots2 ) {
<!-- BOTTOM SPOTLIGHT 2-->
<div id="ja-botsl1" class="wrap">
<div class="main clearfix"><?php if( $this->countModules('user6') ) {?>
<div class="ja-box<?php echo $bots2['user6']['class']; ?>" style="width: <?php echo $bots2['user6']['width']; ?>;">
<jdoc:include type="modules" name="user6" style="jamodule" />
</div>
<?php } ?><?php if( $this->countModules('user8') ) {?>
<div class="ja-box<?php echo $bots2['user8']['class']; ?>" style="width: <?php echo $bots2['user8']['width']; ?>;">
<jdoc:include type="modules" name="user8" style="jamodule" />
</div>
<?php } ?><?php if( $this->countModules('user9') ) {?>
<div class="ja-box<?php echo $bots2['user9']['class']; ?>" style="width: <?php echo $bots2['user9']['width']; ?>;">
<jdoc:include type="modules" name="user9" style="jamodule" />
</div>
<?php } ?>
</div></div>
<!-- //BOTTOM SPOTLIGHT 2 -->
<?php } ?>
<?php
$spotlight = array ('user1','user2','user7');
$botsl = $tmpTools->calSpotlight ($spotlight,$tmpTools->isOP()?100:99.9);
if( $botsl ) {
<!-- BOTTOM SPOTLIGHT 1-->
<div id="ja-botsl2" class="wrap">
<div class="main clearfix"><?php if( $this->countModules('user1') ) {?>
<div class="ja-box<?php echo $botsl['user1']['class']; ?>" style="width: <?php echo $botsl['user1']['width']; ?>;">
<jdoc:include type="modules" name="user1" style="jamodule" />
</div>
<?php } ?><?php if( $this->countModules('user2') ) {?>
<div class="ja-box<?php echo $botsl['user2']['class']; ?>" style="width: <?php echo $botsl['user2']['width']; ?>;">
<jdoc:include type="modules" name="user2" style="jamodule" />
</div>
<?php } ?><?php if( $this->countModules('user7') ) {?>
<div class="ja-box<?php echo $botsl['user7']['class']; ?>" style="width: <?php echo $botsl['user7']['width']; ?>;">
<jdoc:include type="modules" name="user7" style="jamodule" />
</div>
<?php } ?>
</div></div>
<!-- //BOTTOM SPOTLIGHT 1 -->
<?php } ?>
<!-- FOOTER -->
<div id="ja-footer" class="wrap">
<div class="main clearfix"><div class="salogo">
<img src="<?php echo $tmpTools->templateurl(); ?>/images/<?php echo strtolower ($tmpTools->getParam(JA_TOOL_COLOR)); ?>/salogo-small.png" alt="SA Logo" />
</div> <div class="ja-info">
<jdoc:include type="modules" name="user3" />
<jdoc:include type="modules" name="footer" />
</div>
</div>
</div>
<!-- //FOOTER --><jdoc:include type="modules" name="debug" />
addSpanToTitle();
jaAddFirstItemToTopmenu();
//jaRemoveLastContentSeparator();
//jaRemoveLastTrBg();
//moveReadmore();
//addIEHover();
//slideshowOnWalk ();
//apply png ie6 main background
</script>
</body></html>
February 26, 2010 at 4:34 am #333942Hi DreamWeb
I am sorry but i coud not find a problem with your index.php file. I think it is right
For the reason, please send me your live url, admin account via PM so that i could have a closer look on the issue
This topic contains 4 replies, has 2 voices, and was last updated by Anonymous 14 years, 8 months ago.
