  • veeco Friend
    #155457
    hello, i’m adding new block layout in my setting:
    <blocks name=”top” style=”xhtml”>
    <block name=”top-panel” type=”modules” style=”raw” main-inner=”1″>top-panel</block>
    <block name=”header” type=”header” main-inner=”1″></block>
    <block name=”mainnav” type=”mainnav” main-inner=”1″></block>
    <block name=”cpanel” type=”usertools/cpanel”></block>
    <block name=”topsl” type=”spotlight” main-inner=”1″>user1,user2,user3,user4,user5</block>
    <block name=”top-header” type=”modules” style=”raw” main-inner=”1″>top-header</block>
    </blocks>
    however, when i display it… the top_header get slide to the right , i’m test it with ?tp=1.. it slide to the right..
    veeco Friend
    #359665
    solved.. it seem “top-header” is reserved word for t3 template… change it to top-fullheader or something else solve the problem
This topic contains 2 replies, has 1 voice, and was last updated by  veeco 14 years, 2 months ago.
