November 8, 2006 at 5:42 pm #117588
When i click on add a product the right hand column doesnt collapse.
I have read through the readme.txt and looked through the code and cant see what im doing wrong?
any advice greatly appreciated 🙂
great template btw 🙂
November 14, 2006 at 7:17 pm #211650Unfortunately mine does the same thing and I haven’t been able to figure out how to get it to collapse even thought I tell the modules to appear on only the main page..
November 22, 2006 at 5:04 pm #211928Anyone else happen to have this happening or know how to get the right hand column to collapse?
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
November 23, 2006 at 2:37 am #211940Could you provide your live site url here?
November 23, 2006 at 4:19 am #211949But of course..
My site is at http://www.cyclenutz.com and you’ll see that the right column doesn’t collape.
- November 2013
November 23, 2006 at 7:36 am #211953To collapse right column on a specified page, you just only do not allow any modules showing on position top and right. Select which page a module is shown:
November 23, 2006 at 1:00 pm #211962To collapse right column on a specified page, you just only do not allow any modules showing on position top and right. Select which page a module is shown:</blockquote>
Yes, on my site all of the modules published in the Right position are only supposed to be published at the “mainmenu | Home” section as you can see from the image I’ve attached.
:confused:
- November 2013
November 23, 2006 at 3:50 pm #211965In this case, the system understands that “Add to cart” page is sub page of Homepage. You should try to add a mainmenu item link to Virtuemart component.
November 24, 2006 at 2:56 am #211980In this case, the system understands that “Add to cart” page is sub page of Homepage. You should try to add a mainmenu item link to Virtuemart component.</blockquote>
I’m not sure I understand what you mean by addin a mainmenu link.
FWIW it doesn’t only happen on the Add to Cart page. If I click on any product category or a product it does the same thing.
It the example I’ve attached ou’ll see that I clicked on Bags and Luggage and the right column is still visible. Then when I click on an item it is once again still displaying.
- November 2013
November 25, 2006 at 3:55 am #212003Did you try to add a mainmenu item linking to Virtuemart component? On our demo, the menu item “Products” links to Virtuemart component.
November 25, 2006 at 5:00 am #212011<em>@khanh 4388 wrote:</em><blockquote>Did you try to add a mainmenu item linking to Virtuemart component? On our demo, the menu item “Products” links to Virtuemart component.</blockquote>
So it seens that I need to do things that defy reason to me 😉 .. I didn’t understand how just adding a menu item to the mainmenu would change the way clicking on product categories, product details, or add to carts..
I still don’t understand why it worked. All I know is that I added that to the mainmenu and now the right column does go collapse as I had wanted it to :confused: .
This might be something to throw into the readme.txt file that comes with the package 😀
Thanks again for your help in solving this elusive problem.
AuthorPostsViewing 11 posts - 1 through 11 (of 11 total)This topic contains 11 replies, has 3 voices, and was last updated by tonydel 18 years, 1 month ago.
