tfosnom Friend
tfosnom
- October 2010
- 200 times in 94 posts
March 15, 2012 at 11:53 am #175017Hi all. After adding the top panel module and getting a welcome video displaying correctly (Thanks to Dat Hoang) I need help to get the video to centre in the panel when displayed. Also I need to remove the blue band highlighted in the red frame in the attached image.
Site url is: http://www.monsoftwebdesign.net/nex2/
support login info included in post for support staff to use
Blessings ShaneManos ModeratorManos
- February 2014
- 633 times in 576 posts
March 16, 2012 at 5:05 am #443926Hello,
In order to center the video you can try by adding this to your template.css file
.ja-toppanel-row li {
clear: both;
padding: 0 30px;
text-align: center;
background: url("images/trans-topcpanel.png") repeat scroll 0 0 transparent;
As for the blue band i am not sure if it can be removed. But let me try again and i will reply back assap.
Edit: For the blue band try this
.bg-transparent {
background: none;
1 user says Thank You to Manos for this useful post
tfosnom Friendtfosnom
- October 2010
March 16, 2012 at 7:51 am #443941Thanks pascm for your help, the centreing fix worked but the blue band fix didn’t so I changed the
images/trans-topcpanel.png to black and changed the style.css to make it all black rather than blue
while it kills the display of the date and top menu stuff I can live without those
Blessings Shane
- February 2014
March 16, 2012 at 3:24 pm #444001Hi,
Changing the style.css in the module is not such a good practice but since you did that you can just dissable the use of the background image and also:
.ja-toppanel-button-wraper {
/* background: none repeat scroll 0 0 black;*/ /*disable this */height: 19px;
position: relative;top: 0;
width: 100%;
z-index: 10;}
That’s the result i am getting for your site:
tfosnom Friend
tfosnom
- October 2010
March 16, 2012 at 4:03 pm #444008Hey pascm
Kinda lost me, mate I dont see those results at all, nor do I see that code in the mod_toppanel style.css
I have this code.ja-toppanel-button-wraper {
position: relative;
z-index: 10;
top: 0;
width: 100%;
height: 19px;
background: black;
}and I want the inner panel background to be black, just want the menus text etc to show
Cheers Shane
- February 2014
March 16, 2012 at 11:20 pm #444072I am lost too now I can’t find the code again! I visited your website and the code is not there! 😎
Anyway please let me know if you need any more help as this is actually a customization issue. Maybe if you try a bit more you can find the code it must be somewhere there :laugh:Regards
- October 2010
March 17, 2012 at 6:35 am #444102Hi mate
You’re correct its more a customisation thing than a template problem and your help is well appreciated. You may have visited my site during updates LOL. I can’t remember all the changes I made , guess I should add comments to my .css files.I guess it works well enough for whats needed ATM. Again thanks for the continued fast & professional support you and others here provide for us.
Blessings Shane -
Viewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 2 voices, and was last updated by tfosnom 12 years, 10 months ago.
